Share your Armoury Crate overclock, battery optimization & key mapping HERE!
Anders_ASUS
Hall of Fame III
It's possible to save your Scenario Profile settings in Armoury Crate as files in case you ever need to reset your device.
This possibility is also perfect for sharing your favorite settings with others. Maybe you have found the perfect overclocking setting or a way to save 20% battery life without lowering the frame rate. Maybe you consider your key mapping for the Kunai Gamepad or Mobile Desktop Dock to be the best and you want others to try it too.
To share your settings. 1. enter Armoury Crate 2. go to Scenario Profiles 3. press the share button in the top right corner 4. upload the file to your google drive 5. either download the file from your google drive, zip it and upload it here, or just share your google link with permission set to "anyone with the link can view" 6. make sure to include the following information [Game Title] [Included settings] To import settings. 1. Download the file to your device. It doesn't matter which folder. 2. enter Armoury Crate 3. go to Scenario Profiles 4. press the download button and the profile will be located automatically 5. when you have pressed the downloaded profile you can uncheck the settings you don't want to overwrite.
58 REPLIES 58
Gabe
Anyone has a good killer profile to use with asphalt 9? Even with X mode on and everything maxed out the frames drop to almost 30 fps at certain areas, even with the cooler on. Anyone, please? Thanks in advance.
OPC
Zen Master II
Gabe
I have drop only when waiting for the race to start and similar low action moments. When the action starts fps stay over 50. All X-mode settings set to max and cooler blowing on max all the time.
midhu989
Anders_ASUS
To share your settings. 1. enter Armoury Crate 2. go to Scenario Profiles 3. press the share button in the top right corner 4. upload the file to your google drive 5. either download the file from your google drive, zip it and upload it here, or just share your google link with permission set to "anyone with the link can view" 6. make sure to include the following information [Game Title] [Included settings] Comment what you have done and why others should use your settings.
I'm using a ASUS max pro M1(X00TD). Unable to cast my screen to MiTV(Android 9). After connecting tv displays the current screen of the cell phone only. Then no changes . How to resolve this issue
Gabe
OPC
https://zentalk.asus.com/en/discussion/comment/90302#Comment_90302
Are you using hardcore settings or just the X mode slider set to ultimate? If in hardcore, then you're maxing out every slider to the right? I don't really know what all those options do. Haha. I'm sure there's a way to better optimize it but, then again, it's a lot of settings I never even heard about, so I don't know if just maxing them out will help or not and I can't find a guide explaining all of it. Thanks for you reply!
OPC
Zen Master II
Gabe
https://zentalk.asus.com/en/discussion/comment/90797#Comment_90797
Here are the screenshots of all my settings. Be sure in display to turn anti aliasing off! With that option on my game was a disaster! Huge frame drop and crashing always on same ramps in races! Also inside the game put display setting to performance and not default.
