Share your Armoury Crate overclock, battery optimization & key mapping HERE!
Anders_ASUS
Hall of Fame III
It's possible to save your Scenario Profile settings in Armoury Crate as files in case you ever need to reset your device.
This possibility is also perfect for sharing your favorite settings with others. Maybe you have found the perfect overclocking setting or a way to save 20% battery life without lowering the frame rate. Maybe you consider your key mapping for the Kunai Gamepad or Mobile Desktop Dock to be the best and you want others to try it too.
To share your settings. 1. enter Armoury Crate 2. go to Scenario Profiles 3. press the share button in the top right corner 4. upload the file to your google drive 5. either download the file from your google drive, zip it and upload it here, or just share your google link with permission set to "anyone with the link can view" 6. make sure to include the following information [Game Title] [Included settings] To import settings. 1. Download the file to your device. It doesn't matter which folder. 2. enter Armoury Crate 3. go to Scenario Profiles 4. press the download button and the profile will be located automatically 5. when you have pressed the downloaded profile you can uncheck the settings you don't want to overwrite.
58 REPLIES 58
Newbie184
Anyone has a great hardcore tuning profile for honkai impact 3rd game? Thanks
jumapao28
Screen in not unlocking when i double tap on the left and right corner of the screen but it works in the center and bottum screen, im using rog phone 2 and it happened during the android 10 update.
techixir
I am not sure, if it’s been answered here but has anyone figured out key mapping for pubg with scope? Whenever I use scope I am unable to use the perspective control.
techixir
ROGuser
Here is an updated profile for keymapping (PUBGM) which I did over the weekend. Now the player can run without using the separate key for "run" (players might need to tinker around a bit based on your existing pubg own control layout, but runs much better than the previous one I uploaded. However, @Anders_ASUS issues 1-4 from my last post still exist, and I request you to please communicate the same to your developers so that they can help.
Thanks!
https://us.v-cdn.net/6031231/uploads/941/BLIULKIORKAK.zip
I am still unable to run after downloading the profile. Are there any recommendations to change in settings ?
kyleashcraft86
Rising Star I
Averan
https://zentalk.asus.com/en/discussion/comment/76691#Comment_76691
Oneplus doesn't support accent colors
Btw just use themes in the meantime
They absolutely do support accent color customization. It was under something different before A10 but still supported nevertheless. It's under customization
