Rogphone 2 problem
1.Battery charging problems after these update
2. Screen automatically turns off while using after these update
3.Some bugs are in these update
4.My mail id: chilakasathish664@gmail.com
ronald1985
Community Legend I
chilakasathish664
https://us.v-cdn.net/6031231/uploads/VP1F75Q98SWU/bugreport-ww-i001d-qkq1-190825-002-2021-03-09-00-2...
Rogphone 2 problem
On A9? What firmware version?
Also, check if you are on the latest firmware.
Screen automatically turning off seems like a screen timeout settings. Check that first.
ARP_ASUS
Community Legend II
Hi chilakasathish664,
Please specify Software version,
Go to setting => System => About => Software information.
Also, please elaborate what kind of Battery charging problems are you facing?
Screen automatically turns off - Have you tried Factory reset after update? How does the screen comes back on? After restart? Also, what's the frequency of the issue?
