Background Mode problem after updated latest firmware.
ZuuGAKz
Rising Star II
Hello, I have a problem with the Background Mode feature after the latest Patch update that I updated yesterday, which is 35.1810. 1810.317. The problem I encountered is that when Background Mode is enabled and then I switch apps or return to the Home screen, the sound from the game will still come out, which normally, the sound would not come out if I did not turn it on in the Notification bar, which was a little shocking and annoying. And when I turn off the sound in the Notification bar, the sound in the game will disappear for a while, and then when I open any media that has sound, such as Youtube, Facebook video, the sound in the game will come back to overlap with the sound of the media that is opened immediately.
9 REPLIES 9
Mattias_ASUS
Hello @ZuuGAKz
Thanks for the information, will forward it to the devs, in the meanwhile, you can turn down the volume specifically for that app in the volume floating window.
Does this happen with all games? Or only with Arknights?
Hi @Mattias_ASUS
Yes, it happens with every game, not just Arknights.
AEDIS
Yesterday I updated to 317, there is no such malfunction, everything works as before. Try resetting the ready assistant to factory settings, if that does not help, then a full reset of the phone to factory settings.
Mattias_ASUS
I can't recreate the same issue, could you please share a video of how it happens?
