11-19-2019 05:10 PM
12-20-2019 08:57 AM
12-20-2019 04:39 PM
12-20-2019 04:57 PM
BarbatosIt was a hardware issue for @Tres and @Matheus_sc . Do you have a Tencent edition phone? Can you check the back of your device to see whether it says Tencent?@LP_ASUS is this for real confirmed that it is a hardware issue? Can i pm you directly and send logs as well? I have same issue
12-20-2019 04:58 PM
meqwerty69Can you look on the back of your phone to see if it says "Tencent"? I have a feeling that it does, and that is the root of your issue.I have the same issue.
And this issue seems to only appear when the 2nd sim is turned on. My wifi, sim1 and sim2 will disconnect and reconnect every so often (all 3 at the same time). It can be seen on the status bar. It also results in very bad battery drain with battery life lasting less than a day.
With only sim1 turned on, the phone behaves as expected. The network reset doesn't happen, and battery life lasts for 2 days.
12-20-2019 05:09 PM
