09-26-2020 07:30 AM - last edited on 01-16-2024 12:42 AM by ZenBot
09-26-2020 07:39 AM
09-26-2020 07:45 AM
vencihTo the suggestions (and the main post for this problem)Hi
Ifter updating my phone to the latest rom - 17.0240.2009.47
I have the following problem:
Cpu stuck on maximum frequency at 2.95 mhz
The phone over heats and the battery drain much faster.
Questions:
Can i use my phone till next update or will be damaged?
When will be update to fix this issue?
And the last question is WTF ASUS?
jasonwchUpdate next week confirmed by moderator:Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
- CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
- Temperature goes high
- Battery drain quickly
- "Android System" also taking all battery usage from Battery page
What I observed:
- From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
- Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
High temperature / CPU usage / battery drain on 2009.47
SwarajSo when will asus send fota fix for current cpu spike n battery drain
October? November? December? Or no updates 🙂
And why is a9 battery optimisation better than a10?
U can optimize it just like a9 but my guesses are u r so concerned about ur newly launched model rog 3 n r being lazy enough to optimize battery n stabilize a10 like a9.
I need everyone to cooperate with each other n stop demanding extra features for now n request mods to relay msg on developer to fix existing bugs n make it smoother like a9 n then only try adding features bcuz whenever u add features n fix bug of 1 issue, the other bug appears... so better way focus on optimization n stabilization asus @CH_ASUS @Anders_ASUS @LP @LP_ASUS
Next Update?
09-27-2020 03:21 AM
