ROG 2 Custom & Default sound/ringtone issue
michelangalo
I have added a custom ringtone and now i don't see system sounds.
There should be a way to see system sounds without deleteing custom sounds. Attaching video to show the same.
2019-11-14-09-30-45.mp4
4 REPLIES 4
Anders_ASUS
Hall of Fame III
This is a bug. It's not supposed to look like that. I don't know how to fix it. You could try to go to settings -> apps & notifications -> see all xxx apps -> three dot menu in top right corner -> show system -> settings -> storage & memory -> clear storage. Maybe you need to do this for the "settings storage" app too. I'm really not sure if this will work and it will reset a lot of your settings but it's still better than doing a full factory reset.
michelangalo
Anders_ASUS
I really don't want to impact any settings. Can you kindly forward this bug to the dev team so they can look into this.
Anders_ASUS
Hall of Fame III
We can log your device. Without anything to go on, we will never find this bug.
I can send you a PM with instructions
Anders_ASUS
Hall of Fame III
michelangalo
https://zentalk.asus.com/en/discussion/comment/28730#Comment_28730
Our dev team has looked at your log file and can confirm that this bug is due to that you've installed a xiaomi file explorer which is not compatible. Uninstall it, remove the custom sound and add the sound using our file explorer. Hopefully your sounds will start working again.
