no flashlight when using OTG in low battery
Shubhangkar
26 REPLIES 26
dhenz_isip
Im also having this problem i have tencent version and its annoying when playing. How to fix this.
dhenz_isip
Anders_ASUS
dhenz.isip
yoga_agustina
I have the same problem as well.
it keep shows up while battery below 15%
and the bottom charger port also not working.
I've been using this phone for 3 months.
Anders_ASUS
Hall of Fame III
Shubhangkar
adams.toomer
I'm getting the same thing and I can't use the bottom port to charge. You find a fix?
lung-butter
Same exact problem here. WTF, brand new ROG phone 2.
arif.malufi
https://zentalk.asus.com/en/discussion/comment/46417#Comment_46417
@Anders_ASUS its always like this when the battery low , twice / second i think
devraj.ja
It's always showing " No flashlight when using OTG in low battery" automatically comes when battery is less than 15%. I can't use bottom part of display as well drop down menu. Please let me know how to resolve.
Park83
https://zentalk.asus.com/en/discussion/comment/69655#Comment_69655
Hi, I am having the same issue. As of writing my phone is at 50% so I cannot replicate the issue. But when battery is ~15% the phone will persistently show this error. It is as if the phone thinks it is connected via OTG and that the flashlight is on (as the error says) when it is not on both counts. And that this 'false OTG' connection keeps on disconnecting and reconnecting. This makes swiping down the notification tray difficult. In USB mode menu, I think, you can see that the phone is reconnecting and disconnecting.
I have raised this issue with tech support and they recommend a factory reset but that is not an acceptable solution for me.
dhenz.isip
yoga.agustina
Can you please check if the OTG function (connecting external HDD) works when the battery is above 15%? Thanks!
cyberlord76
Same issue for me
