my phone battery is being drained drastically. please do fix the issue.
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
nationkid
Rising Star II
Please read the forum posts on here before making yet another topic on this.
FOTA drops next week to fix this.
I was having same issue after i updated to android 10 i thought that after few days of uses it will get normal then i waited for updates after update same issue battery drain , high ideal cpu uses and device heating while doing nothing , at last I finally downgrade to Android 9 and all the issues as solved . I suggest you to downgrade to android 9 , and wait for Android 10 issue to be solved then upgrade back to android 10 . After downgrade to Android 9 I am getting around 10 hours screen on time . Much better than android 10 .
ARP_ASUS
Community Legend II
Hi Closing this thread. This is a known bug. New update will resolve the same.
