Kunai right analog drift issue (bumper case)
Zenpai
Hi, I would like to report regarding the kunai right analog drift issue. The issue occurs when you're tilting the right analog gently to left, then after releasing, the input seems still register as if you're still tilting to the left. Then I need to slightly tap the analog in order for the input to return at the center. I've encountered this while playing BDM, which has a sensitive right analog control for camera view. I dunno if it's only for me but I've tested it both on bumper and the holder via direct connection, it only occurs when using the bumper. Here is some screenshots when i tested the values registered by the kunai when replicating this issue. The normal values of the right analog x axis when in center is - 0.003921509
Any ideas @LP_ASUS ? Thanks
7 REPLIES 7
LP_ASUS
Community Legend I
Zenpai
Me? No I have no idea, but I can ask the people that do. 😉
Keep in mind we're in the middle of a holiday so turnaround time will be slower. But I'll forward this to R&D and see if they have any suggestions.
Zenpai
Thanks for forwarding it.
LP_ASUS
Community Legend I
Zenpai
We're investigating the root cause, but a short term solution is to connect with Bluetooth instead of a direct connection. That should mitigate the issue. I'll update when I have a true solution.
Zenpai
LP_ASUS
https://zentalk.asus.com/en/discussion/comment/35920#Comment_35920
Thanks. Please do take note this only happens using the bumper case / handheld. The issue does not occur when using the holder via direct connection or bluetooth. Thanks again.
