09-23-2020 04:27 PM
09-25-2020 04:10 AM
09-25-2020 04:19 AM
09-25-2020 04:27 AM
Gustav_ASUSwill it fix batteryHi guys,
Just going to pop in and let you know that we're aware that there are multiple issues being reported by users in this thread and that we've opened separate cases for them. (Google Play, Armoury Crate etc.) Our developers are investigating as we speak. We will address this and issue a new FOTA as soon as possible.
Thank you for all the detailed responses so far!
09-25-2020 04:29 AM
jfkeiuxjeThe big battery drain issue? Yes. Because its the CPU at near 3Ghz draining the battery basically. THe heat issue is due to the cpu working overtime.https://zentalk.asus.com/en/discussion/comment/118068#Comment_118068
will it fix battery
09-25-2020 04:50 AM
jasonwchI am on the latest version on the firmware and I did get the high CPU and heat after the update.https://zentalk.asus.com/en/discussion/comment/117472#Comment_117472
are u on 2009.47 WW? After that play service updated, u dont hv CPU spike after install any app from PlayStore or APK?
