09-23-2020 04:27 PM
09-25-2020 03:11 AM
09-25-2020 03:15 AM
nationkidWell, actually the reset is probably going to solve the issue since you will lose the latest update (I think) and you will get an older Android 10 version, probably the first one released. After that, you will need to avoid the updates.This is a tricky one also. I have contacted support in the hopes of a fix or some form of resolution because I cant use my phone really, its constantly hot and causing it to restart or the battery only lasts 4 hours if fully charged.
Support are telling me to do a full factory wipe/reset which I think is so stupid. It's not going to fix the issue at all.
09-25-2020 03:18 AM
AndreaSadly it has not resolved it, its just removed all my user settings and apps and start a new but on this bugged firmware.https://zentalk.asus.com/en/discussion/comment/118028#Comment_118028
09-25-2020 03:49 AM
09-25-2020 04:04 AM
