Big Problem!!! Bluetooth issue
ZT-60b1fd86
I have observed that we can't hear anything from bluetooth headset when we are on video calls or normal voice calls. But all songs and youtube videos sound are able to hear from bluetooth headset. I have regular meetings on hangout and whatsapp and can't use bluetooth headset this is big issue in current situation.
All is fine when we use wired headphones.
@CH_ASUS @Andrea@andersent310@Anders_ASUS
5 REPLIES 5
Anders_ASUS
Hall of Fame III
coolkhalid59@gmail.com
Sounds like you have only set you BT headset as a media device and not as a headset. You can fix this by going to the properties of that device in your BT settings
ZT-60b1fd86
Anders_ASUS
https://zentalk.asus.com/en/discussion/27624/big-problem-bluetooth-issue
All the three options are enable.
Anders_ASUS
Hall of Fame III
https://zentalk.asus.com/en/discussion/comment/77191#Comment_77191
Then I don't know. Try going to system settings -> system -> reset options and then reset wifi, mobile and BT
ZT-60b1fd86
Anders_ASUS
https://zentalk.asus.com/en/discussion/comment/77261#Comment_77261
Done that the issue solved
