Low microphone voulme on Phone calls specially whatsapp, snapchat and other apps
msaiq79
I have Asus rog phone 8 pro. the problem is when i make calls using wired headphones people complaining that they. can barely hear me, i tried alot of headphones with USB-C or 3.5mm and still same issue. I tried on Meta messanger, whatsapp, Snapchat all of them are having the same issue. the phone is updated with the latest update but i am facing this issue since day one that i bought the phone in. Phone audio is choppy with AI Noise Canceling on, and low and noisy with it off. I have to hold the phone at the bottom so my voice is reflected into the mic.
I am on the latest software update and when i got updates never solve the problem. Voice calls over Snapchat are terrible using USB-C headsets. I tried many brands with the same problem
Koudmaker
Rising Star II
What power profile are you running?
I dont know, how to check that ?
msaiq79
Bump this up?
