04-23-2020 12:46 PM
04-26-2020 09:58 AM
04-27-2020 08:57 AM
04-27-2020 01:20 PM
shreyashshah16Basically PCMark battery test makes the same calibration. I was running that test 4 times (overnight) since A10 update and every time battery life has been improved. I did it in first place because after A10 update battery life got shorter comparing to A9 so I wanted to check.@Sourabh @Akash Gupta @ishaan.gupta10 @sathish05durai,
Guy I had exactly same issue till tomorrow. Device usually heat more than it should, even in apps like web browsers, social media apps etc. And i wast only getting SoT of 6:30-7:30hrs, which considering my usage is 1:30-2hr less. (Previously i was getting 8:30-9:30 easily).
So here is possible SOLUTION:
Today morning, i let my phone die completely to 0%, and allowed it to auto shut down, then I put charger back on, and started device @4-5% charge, kept it on charge till 100%.
(ps: i noticed that during discharging phone stayed @1% for freaking 15mins, i had to activate NFC LOCATION XMODE FLASH LIGHT, to kill it to 0%, so that makes sense that definately something was wrong with % calibration)
This of course you may already know as BATTERY CALIBRATION, and it worked. Not I'm sitting at 4:30+ hr SoT @60% charge also Device no longer heats that much. (With 120FPS, bluetooth on all the time and on Wifi, brightness at 75%+)
I know its weird, battery calibration should fix BB but how come it reduced heating, I don't know. And THATS WHY I'M REQUESTING YOU ALL TO TRY DOING THE SAME AND PING HERE IF IT WORKED FOR YOU!
05-03-2020 11:19 AM
05-05-2020 10:23 AM
