07-22-2020
09:28 AM
- last edited on
01-16-2024
12:56 AM
by
ZenBot
07-30-2020 09:26 AM
07-30-2020 12:44 PM
ARP_ASUSI'll do that but just for reference When i didn't play pubg, and used the phone normally the sot was around 7-8 hours on 120hz. When i did play pubg (1.5hrs) the sot barely reached 5 hours. All other usage was about the same.Hi @Kanu
The battery consumption can differ device to device.
The ultimate parameter is the SOT (Screen on time).
Can you tell me how much SOT do you get?
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
