More suggestions for ROG Phone 9 pro
DemiDoom
Hello to the great Dev team of Asus!
I have 2 more QoL suggestions that i thought would be of a great use for us, users.
1. Charging Indicator:
Since i started using the ROG 9 pro i've noticed that every time when the phone charges to 100% battery, the LED still glows in red light.
It would be very practical and helpful if we could see the LED indicator showing us that the battery is fully charged without having to pick up the phone and opening the screen to see if it's fully charged or not, let's say with a green LED light.
2. Alarm Clock:
I've also noticed that when i put my phone on vibrate mode, the alarm's ringtone would still go off. It has put me in awkward situations where i'd have to pause a conversation with my clients to turn the alarm off. I think that on vibrate mode the alarm should only ...vibrate.
You could make the ringtone go off on vibrate mode only when we have or earphones or earbuds plugged in, that would be a great option to have.
Thank you very much!
CHOOZR
Zen Master I
seems like you have a bug. cause for me the green led does show up. so i know the battery is 100%
Mattias_ASUS
Hello @DemiDoom ! Thanks for the suggestions!
Regarding the light, would you kindly share a picture?
For the alarm, to be able to have a silent alarm you have you go into the alarm och select "None" as the ringtone, that way you'll get a silent alarm
