05-26-2024 03:01 AM - edited 05-26-2024 04:22 AM
Wired Earphones making Loud hissing noise on my rog phone 8 pro
I could still hear the content i was playing but the hissing sounds so bad..
When I connect my earphones at my aeroactive cooler X or using the type-C to 3.5mm audio jack , it sounds normal
==================Edited=================
I found that the hissing sounds happens more louder on games. And I hear the lesser noise on music or video (non-game apps)
a month ago
Hello @AlexH
Could you please share a screenshot of your settings in AudioWizard? And also your firmware version please 🙂
a month ago - last edited a month ago
Hello, @Mattias_ASUS
I didn't touch anything at Audio Wizard
And the firmware version is 34.1420.1420.387
And also the content sounds more weaker then when I connect via Aeroactive cooler X 3.5mm port or usb C to 3.5mm jack or Bluetooth earphones
a month ago
And also the content sounds weaker then when I connect via Aeroactive cooler X 3.5mm port or usb C to 3.5mm jack or Bluetooth earphones
3 weeks ago - last edited 3 weeks ago
facing the same issue even when im using dongle dac still got noise, the noise coming after every sound
