Wired Earphones making Loud hissing noise on ROG 8
atiqsazal
Most probably my audio port is damaged. But I don't know what caused it. When I put the audio jack in yesterday I only got this loud hissing noise like the TV's used to make when there was no signal back in the days. I could still hear the content i was playing but the sound was weak.
Any guesses on how it may have been damaged? I normally play Pubg mobile only and i take good care of my phone. Also the earphones(KZ zsn pro 2) work perfectly on my other phone.
benjaminfernand
I am facing the same issue on my headphones, Sony CH720n,
AlexH
Rising Star II
I also have a same problem...
It's works fine when i use the port on aeroactive cooler...
