Tasker Project for easy swap charging bypass
SirMaus
If you add this Profile to Tasker (Tasker with AutoInput plugin). You can very easy switch the charging bypass function. Check the pictures for settings/more Informations
Download: http://gee.myasustor.com/Charging_bypass_beta1.zip
Tatsky
Actually, there's an option inside the Game Genie where when you're on a game, you will just select whether you want to activate bypass charging for that particular game or not. And if you activated it, every time you open the game and insert your charging cable it automatically activates the bypass charging.
Not sure with other ROG 8 users but been using it (with only 1 time activation) for quite some time now when griding Warzone Mobile. 😅
Oh thanks very much for this Information. I found the option in game genie today. But i cant add the camera tool. I need this bypass if i record 6 hours 8k videos.
Ah, that I don't have an idea. Your tutorial will surely be perfect for such use.
