ROG Phone 8 Pro Problem with WiFi Calls
Raven1
Hello i have a problem with my current ROG Phone 8 Pro. As soon as i connect to any WiFi network i am unable to do or receive any calls. If i try to call someone i get a notification to activate WiFi Calling (what i already did).
I observed that once i connect to a Network my SIM card permanently switches between disabled and enabled, wich results in my phone number not registering correctly.
I just installed the latest update but the error remains. It is not a SIM Problem, in a different Phone everything works fine. Its not a WiFi Problem, this happens with any Network that has an internet connection (i also tested a Network without an internet connection and here my SIM stayed aktive).
Does anyone had similar problems, or does someone has an idea that might help?
Mattias_ASUS
Hello @Raven1
Which firmware version are you on? And I was wondering if you could create a log so the devs can look into the issue.
For this I will write the steps down below and make sure to start the log process before connecting to WiFi and then trying to recreate the issue.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
