RoG Phone 8 low headphone volume problems despite being on max.
Chubbsterish
Hey everyone, I will try and keep this short if possible. I am using the Rog Cetra II headphones. After the two lastest updates (I thought the new update was going to fix the problem) my max volume is slashed by like 50%. Despite having everyone on max the volume is still very low and it makes no sense compared to before. I'm trying everything to avoid factory resetting my phone. Any help is appreciated. I've went in as dev increased the volumes. Cleaned the headphone jack, played with the Audio Wizard, adjusted so it's correct headphones, checked the box and unchecked the box in Armory Crate nothing is helping. I've done everything possible in all volume settings and my volume is still very low on my headphones despite having it on max volume. I've tried with other headphones still same problem.
Any help trying to fix this is appreciated I'm about to lose it since there was nothing wrong with the volume two updates ago.
This problem persists on all apps. Spotify, Youtube same crap.
12 REPLIES 12
Reset your EQ and remove that preset.
Clean your earbuds or even your ears xD.
I've already reset it countless of times its the same problem and yes ive cleaned my ear buds.
Doesn't your earbuds have a separate app?
Just to be clear Mattias even if I push all the bars to the max in the Audiowizard I can barely hear the difference. There was nothing wrong before the latest 2 updates.
Chubbsterish
Its the Asus Rog Cetra II with the headphone jack not the wireless ones. So armoury crate is my app. I've done everything possible and its still sounds like the volume is at 50% when its at 100% It's just way too low for something thats meant to be 100%. I've tried with different headphones like I've said before so it has nothing to do with cleaning anything so lets drop that part of the topic from now on. I've done all the captain obvious things cleaning the input jack, earbuds etc done wahtever I can within the phone with the volume levels, reset the audio wizard etc despite all of this its just too low. This wasn't a problem 2 updates ago thats for sure since I thought the newest update would fix that but the problem remains.
