11-04-2025 09:21 PM - edited 11-04-2025 09:33 PM
Model Name: ROG Phone 8 Pro
Firmware Version: 35.1210.1420.150
Rooted or not: NOT
Frequency of Occurrence: Always
Hi Asus Team,
I am having a strange issue with color rendering on the lock-screen when I turn on the fingerprint feature. This only occurs with a fingerprint function on, the lock screen became more yellowish. After turn off fingerprint it became normal as white color that is same with my home screen. I can sure it occur only after fingerprint is ON.
It also occur from all range of brightness and refresh rate.
Can anyone please try to check and populate/recreate the issue?
No screenshot is provided because that screenshot's color look fine. its the display itself.
Similar Issue Case:
https://zentalk.asus.com/t5/rog-phone-6/lock-screen-issue/td-p/251244
a month ago
Hello @Jinjianlee
It sounds like something might be triggering the Eye protection mode, can you check if that feature is enabled?
Also, would it be possible to get a log while recreating this issue? I would like the dev team to look at it.
Feel free to send me a DM when you are done.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
4 weeks ago
https://drive.google.com/file/d/1sBA1crDnfZjB1CPX4xO90heliudFXiDW/view?usp=drivesdk
here's the log for mine
3 weeks ago
Hello @Elesia
It seems the file might be locked, please share the link to "everyone" so I can share the link to the devs.
I'm sending you a DM 🙂
4 weeks ago
I'm having the same issue as well. It's just as you says it only occurs if you set the fingerprint on though my refresh rate doesn't have the issue, the part which the brightness lower itself is at least the same.
