2 weeks ago
I messed up and dropped a beer on my charger, where can I buy a new 65w one?
Solved! Go to Solution.
2 weeks ago
Was checking and you can buy a new charger here: https://www.asus.com/se/accessories/adapters-and-chargers/rog--republic-of-gamers/filter?Series=ROG-...
I also noticed that the ROG Gaming Charger Dock for the ROG Ally can be bought there, I have tested it and it not only works as a charger but also does indeed work as a dock too! So there you have 2 alternatives 🙂
2 weeks ago
Hi @RobLake
In which country are you in?
2 weeks ago
Sweden
2 weeks ago
2 weeks ago
Had no idea!! Is there any difference in the charging speed?
