Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
SimoRog5
Secondo me possono aggiustarlo perchè il problema lo riscontro in sessione di gioco.  nel mio caso gioco a call of duty; quando devo sparare e muovermi nello stesso momendo, quindi fare click sul trigger e sullo schermo, va in conflitto, anche il touch ha problemi mentre gioco, se io devo volare con l'elicottero e devo andare in avanti, il movimento in avanti non rimane attivo , con il dito sempre appoggiato sullo schermo l'analogioco di sinistra ritorna nella posizione centrale come se io tolgo il dito sullo schermo. spero mi avete capito
Tomek
I now have ROG 8pro and have the same problem. Triggers are unstable only during gaming, but during non-game testing they work perfectly.
In RED MAGIC triggers work great. Asus, aren't you ashamed?
Zцlц
For me its not just the triggers. The whole touch feeling is super slow compared to my ROG7 touch. I just bought this phone to play WZM with the bew chipset, but it was my biggest mistake ever.
errorTamilan
I have Rog 5s and Rog 8 Pro
Now I use Rog 5s Trigger working best but Rog 8 Pro worest triggers
so  I left it rog 8 pro it's just for sleeping mode😴😴
Unlock tool also gone totally rog products waste
I do agree with you, my ROG6 triggers worked way better than my ROG8 Pro. With the latest update on the triggers, it's definately better than when I first got the ROG8. Now I realized when i press the left trigger fast enough, the right trigger will activate as well. Scary as hell.
