Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
221 REPLIES 221
kantaphat888
I have every model but this ROG 8 pro is the worst of them all. Latest product is worst so should be opposite. Waste of money if they don't guickly to new update to the trigger you will shock the Nubia trigger performance
Clear data and cache for the armory crate. Uninstall the armory crate and reinstall it. Restart your phone. If possible uninstall the game too. I guess this happened after the armory crate update right or system update . Mine the same . That's how I fixed it
Yeah well your high on crack it's literally the phone flexing I said it like 2000 times on here you guys released a **bleep**ty azz phone and ripped us all off should have tested it better
Yeshua00
Altair4300 I told you it's a structural thing no setting is going to fix the phone its literally flexible to the point where it affects the buttons armory crate and cache has nothing to do with it you need to recall the phone you guys have like 5000 people complaining about your triggers I want my **bleep** money back or the next phone that aint screwed up
Altair4300
Am sorry brother, that's Asus for you. I even tried hitting my phone multiple times at those tigger sites and trying to flex it, a little. After some minutes my trigger became responsive. They got to refund you or change your model as far as you had no repairs done to the phone. That's quality issues
