Mobile Legend Bang Bang stuck at 60fps after I updated Android 13 to Android 14 on rog 7
Teguh95
Dear developer,
After I updated Android 13 to Android 14 on my rog 7, MLBB doesn't running smoothly and stuck at 60fps (before I upgrade I can reach 120fps with ultra graphic setting).
Are you kidding me?
If you give me factory reset as the solution and re-install the system package, that will waste my time.
 Please fix this issue ASAP.
12 REPLIES 12
  • Thanks for the info, Thank You Verymuch and By The Way, not MLBB Only compatiblity issue, every games the same issue
JimiK
Rising Star I
And some games refuse to open.
tomorrowland
Same problem in Asus brand new flaship ROG8
🤣🤣🤣Not worth to buy,regret that i bought ROG8 last week
