Bypass charging issue with Aero Active Cooler 7
R4ZE
Im using rog 7 ultimate with the latest update WW-33.0820.0810.208. Bypass Charging without the cooler seems to work properly however, when aero active cooler is connected that's when the bypass charging seems not to work anymore, the battery percentage slowly decreases. I already tried playing with different settings like using different cooler settings from frozen, frosty and cool combine with dynamic and ultra durable and also lowest settings in game but to no avail. Hopefully this problems gets fix asap as I see in the forum there are others having the same problem
20 REPLIES 20
It didn't come to me. Did you see it after the update?
Yes, but wasn't able to take a screenshot of it. You can check on your system if its already been updated.
 mine like this after update and reboot
That's what I was asking. It didn't come to me.
No, it didn't, they just cut the performance of the device so it won't get hot, I explained it in detail in my last post.
