Rog phone 6 pro microphone issues
Vha
Hi, my asus rog phone 6 pro is having microphone issues, when im trying to speak on the phone, the person on the other end cant hear me. Some times the microphone would work and then it would randomly stop working again for few hours up to couple days. I bought this phone brand new and have been using it for few months, the first couple months had no issues and then all of a sudden the mic would stop working and start working again. Anyone else having this issue? And how do i fix it? Thanks
4 REPLIES 4
taihs85
Me too, ROG 6 microphone not working, whatsapp voice no sound, video recording no sound, and after restart its working again, then happen again in few days/weeks
Vha
is there anyone that can help?? it's happening a lot and im getting frustrated and impatient
I have been looking for fixes everywhere, can't find it. WhatsApp, Voice Recorder, ScreenCapture, every Microphone required application will not recognize any audio input. Tried blocking/unblocking my mic, but issue remains.
Only option is to restart my phone
Hey,
Thanks for bringing this to our attention. I'll forward the issue to the R&D, however, before I do that I'd recommend you perform an SMMI test to assess the microphone.
  • Open the Calculator app
  • Type ".12345+="
  • Select Single Test under the SMMI Test
  • Run a test for BoardMic1-2-3
Also, could you please share a log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
