ROG 6 Pro - How to Disable AudioWizard for better Sound Quality (aptX Adaptive Bluetooth)
Tayan
I was wondering if there's a way to disable the DIRAC AudioWizard DSP app as it affects audio quality (both via the 3.5mm headphone jack with UM MEST MK2 IEMs and over Bluetooth using aptX Adaptive with my Noble FoKus Pro TWS).
I know for a fact that this app/postprocessing is causing deterioration in sound quality even when left on the "music" preset with default headphones. Please see attached screenshots which includes my settings with developer options as well.
I'm coming from an LG V60 and expected the SoC DAC to be a downgrade with plugged IEMs but it should be identical over Bluetooth since it supports aptX Adaptive (and Lossless at that) - it's just that the AudioWizard is interfering and if I cannot bypass that then I'll have to return the phone as it is a dealbreaker.
Model Name: ROG Phone 6 Pro
Firmware Version: 32.2810.2210.216
Rooted or not: No
Frequency of Occurrence: Constant
APP Name & APP Version (If your issue relates to the app): AudioWizard app and any high-res music streaming such as Tidal HiFi/MQA with Bluetooth aptX Adaptive.
22 REPLIES 22
DeLLiAnO
Rising Star I
reebokable1
Im facing the same problem on the new ROG 7. Its unbelievable Asus still hasn't addressed this
ZenBot
Community Manager
Community Manager
