Problem FPS Rog phone 6
Ionut1096
Hello
I have rog phone 6 please
and for some time when I enter call of duty mobile, in a match to be exact
there are moments when the fps drop drastically.. from a constant 90 as I had, it fluctuates to 50-60-70 fps, causing constant lag..
is there any solution??
7 REPLIES 7
mnegreaionut
Se si restarteaza uneori cand deschizi camera?
Nup . N am avut problema cu restartatul ...
Doar drop frame ...de cand cu update ul la soft ...
Dai si tu un hard reset
Nu știu de ar ajuta cu ceva resetarea telefonului ... Odată ce e acelasi soft zic eu..
