Problem FPS Rog phone 6
Ionut1096
Hello
I have rog phone 6 please
and for some time when I enter call of duty mobile, in a match to be exact
there are moments when the fps drop drastically.. from a constant 90 as I had, it fluctuates to 50-60-70 fps, causing constant lag..
is there any solution??
7 REPLIES 7
Daca este vorba de jocul CODM ajuta, am avut aceasi problema...
Te cred . Dar si sa dau reset la tot ... E mult de lucru, când pot si ei a da un update la soft ..
Ionut1096
any news?
still can't fix the fps drop issue...
