Armoury Crate problem
excavation5
Rising Star II
Rog 6 firmware .216
Armoury Crate is very laggy i have problems when i slide it in games some times is very slow it take long time for opening other problem is even Armoury Crate is running very often air triggers dont work and i need to go in air triggers settings after this exit from the settings and this fix the problem also other problem when Armoury Crate crash it show me i have 0% battery when i have 53% in reality
Also other problem is that when i change refresh rate to 120-144-165 that force gpu to run at max frequency and that make the phone to overheat in some games
Mattias_ASUS
excavation5
Rog 6 firmware .216
The GPU working harder for higher framerate is normal, since it needs more power to produce more frames.
Regarding the Game Genie, I will check with R&D
ASUS_Bot
Rising Star II
