Android 15, overheating, "sort of" a problem with the camera, locked RooT and bootloader to fix
Worling
First, I ask to give the opportunity to update version 15 At least in the European firmware. It is even possible to clean it. From which the second request follows, give Root rights as in some other OS, we do not care about the bootloader or alternative OS, we ourselves will climb in and fix the OS problems, at our own risk! We ourselves will finish the LED, camera and frequencies under the same as it was on Android 12 before all the problems. It is not even Full Root, but only access to some directives. Your problems with China do not apply to European phones, so give a loophole only for Us! Why do other brands somehow try to enter the situation although they make Non-gaming phones, and we Gaming ones, suffer from closure? A gaming phone is an advanced user's phone, I'm tired of opening a messenger and flying off into a 5-15 minute reboot of the phone because of the camera, which I accidentally turned on when I sent a meme to friends. Moreover, after rebooting, the camera works in normal mode and there is no problem. If you do not solve the problem in your updates, then let us solve it ourselves! No one will switch to older models until the issue with the person holding the problematic phone in their hands is resolved! Rather, we will switch to another manufacturer with access to root, bootloader and without overheating from a regular minor update!
Worling
press the button to reboot the pc or modem. (good advice, ancient as mammoth **bleep**, the phone is half a year old, the camera is lying down because of Android 14 and its total lack of optimization on Asus, overheating began with Android 14. WITH THE UPDATE TO THE NEW VERSION.) by the way, you don't have such problems in new models, do you? oh, Android 15 melted rog 7 and 8....
