ROG phone 5s battery issues
tedsonchew
Model Name: ROG phone 5s
Firmware Version: 18.1220.2201.186
Rooted or not: no
Frequency of Occurrence: all the time
The battery is abysmal. Over the last 3 days since I bought this, I have tried all kinds of system settings that have been posted here or on the internet but to no avail. Can't even last a day for 6000 mah. My ROG phone 2 outperforms this junk and it's 2 years old!
I have never seen android system take up so much of the battery. It's usually the screen.
15 REPLIES 15
waxy78611
Zen Master I
tedsonchew
Battery life is much better! My phone doesn't heat up after using it for 10mins. Previously it used to heat up even when doing menial tasks. Thank you so much FunBike31! Please try this solution for all of you using 5s!
Dude you're getting 5 hours SOT &, you consider that good ? 😂😂😂
I'm out here getting 11+ hours SOT with 90hz enabled & 13+ hours SOT on 60hz
FunBike31
Community Legend I
@tedsonchew
It's better but it's still bad, Android System must not have 2 digits and YouTube consumes in 7min what it should do in +1h. (my Youtube made 3% in 45 min)
Android System consumption is not linked to the screen as you said above but by a buggy cache or by an active application or in the background that makes calls to Android (API). (we do not see the use of the battery by the application in this case because it uses the calls of the android system)
First, you should clear all caches, remove all background applications, then go to settings, search for Mobile Manager" and run Clean (analyze) then clean.
physically turn off the phone afterwards and turn it back on.
In a second step, it will be necessary to check the parameters of the possible optimizations, such as preventing the applications left from restarting
tedsonchew
@waxy78611 well... that's the best I can have currently....I have tried his solution. What would you suggest I do then to get your results?
tedsonchew
@FunBike31 I have been traveling so I haven't been able to further test your new recommendations. Here are the results.
Android system is no longer hogging the battery and games/screen are where they should be. So right now, I'm getting 19 hours with more game time in. If you can see, the first time with the old firmware, I could do 1 hour of gaming. Now I can hit 3 hours, which is a huge improvement, but could this be increased? 3 hours of gameplay for a flagship gaming phone is still....
FunBike31
Community Legend I
On my games on average I get
around 7am in the evening with very low light (4g or wifi)
5h-5h30 during the day, 80% brightness, (4g or wifi)
in 5G I lose about 1h - I up to -1:30 if it no longer finds 5G
But there is no other use in the meantime except a little messenger and no background application.
BT off, GPS on as a general rule
