07-25-2021 09:45 PM
07-26-2021 05:29 PM
SwaggiePAs you can see at first the video will play, after I try to adjust the volume, it just started to go buffering. I have a stable 4g connection. I open a random profile to try and for homepage of TikTok is still the same. And for Instagram those videos are just going buffering and won't load.https://zentalk.asus.com/en/discussion/comment/178268#Comment_178268
You have any solution? At first I thought my internet was lagging so I switch to my internet data. It's still the same. And then I reinstall the app, it's still the same too.... TikTok app is the worse, it'll make my whole phone become no sound...
07-26-2021 07:35 PM
SwaggiePThanks. I also saw quite a few more users have the same issue after a few videos the sound disappear and need restart the phone.https://zentalk.asus.com/en/discussion/comment/178321#Comment_178321
https://us.v-cdn.net/6031231/uploads/24M6D91N3W1A/2021-07-27-08-23-16.mp4
07-27-2021 01:11 AM
07-27-2021 03:22 AM
Titan_ASUS@mickey10021 @__incisionAU @TITAN this solution works. Go and try it out guys.Hello, could you please help check settings below?
1. For [Settings] > [Accessibility > [Mono audio], is this option on or off on your phone?
2. If "on", please help disable it, then reboot your phone, and check if issue persists. Thanks.
07-27-2021 03:23 AM
SwaggiePOps wrong tag @Titan_ASUShttps://zentalk.asus.com/en/discussion/comment/178417#Comment_178417
@TITAN thanks for the solution!
