PROXIMITY SENSOR ISSUE PLEASE HELP .
BASEL1234
Model Name: ROG 5S
Firmware Version: 18.1220.2112.175 ANDROID 11
Rooted or not: NOT ROOTED
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app): PROXIMITY SENSOR NOT WORKING WHEN CALLING AND WHATSAPP AUDIO I UPDATE THE LAST FRIMWARE AND NOT SOLVED THE ISSUE UPDATE COMING WITH NEW ISSUE 😞 😞 THE DOWN SPEAKER NOISY SOUND NOW ??!!
I TRY TO REMOVE SCREEN PROTETOR AND DO THE TEST .12345+ BUT SAME ISSUE NOTHING CHANGE
Irene2_ASUS
Zen Master I
Hi @BASEL1234
Please check your inbox for a PM from me with further instructions.
Moxy
I have the same problem.... Solution??
Maxwuell
Same issue for a rog phone 3 strix, help please, thank you
