Performance issue After motherboard replacement
hp9976802431
Rising Star II
1.42ghz only throttling(x mode also) In Game play and stuttering issue,can't play smooth .Very worst performance plz fix in update.
53 REPLIES 53
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200704#Comment_200704
This is because xmode sets to max frequency and then gets overridden by the govenor. It has always behaved like that.
What kind of issue this is it a gaming device or else .Update issue, motherboard issue ,thermal paste issue, hardware issue or software issue shame on Asus developers
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200748#Comment_200748
It could be anything at this point. I assumed it was sensor issue but according to @Sarkiri the sensors work fine in Aida64, so it cannot be that. Thermals are fine, so it's probably some sort of thermal management bs.
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200749#Comment_200749
This should be brought to the attention of Asus and This issue needs to be fixed.
Sarkiri
Rising Star II
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200723#Comment_200723
I want to tell something if go armory crate advance hard core setting profile nothing change any, select point number 12 if you value to high and save it it also shows 2.84ghz .But his performance not doing well.only shows 2.84 ghz but cannot apply the game.if you check and reply to me.
You need to adjust the maximum temperature limit and other settings as well, not just the CPU clock speed to get the performance or it will start thermal throttling since the default temperature value is set to 2. I would not recommend increasing the maximum temperature limit too much if you do not have the cooler as the device will heat up very fast, try experimenting with the settings.
You can go to this website and read what each settings does if you want to try it, but its in chinese. You can use google translate to translate it to english.
Sarkiri
Rising Star II
আই টি ইন্দ্র
https://zentalk.asus.com/en/discussion/comment/200741#Comment_200741
How to go to this options showing in Screenshot posted by you? I don't find anything like this in armory crate?
Open Armoury Crate then select any game and press the "Scenario Profiles" Button - Performance Tab - Hardcore Tuning - Advanced - and press the gear icon on the right side.
