01-08-2022 08:55 AM
01-09-2022 01:09 PM
Danishblunthttps://zentalk.asus.com/en/discussion/comment/200588#Comment_200588
The system temp is the temperature you see on armory crate (40-42c). Perfdog is by far the best way of testing your temps while gaming, however you can also use "CPU Throttling test" on play store, remember to turn on temperature in settings when launching it, then you can post a screenshot after running it for 10 minutes.
01-09-2022 01:16 PM
01-09-2022 01:26 PM
01-09-2022 01:52 PM
DanishbluntNumber of thread 100You're supposed to run it for 10 minutes, not just 1. Also It seems some sensors don't report anything, this is most likely a hardware defect, since the sensors don't show anything, the CPU will automaticly throttle all cores except for the first 2 where it has a reading.
01-09-2022 01:57 PM
hp9976802431CPU load alone doesn't throttle, however the problem is the fact that the sensors are dead on core 2-7. If you play games due to not being able to read the temps the CPU goes beserk as the system temp rises because the GPU is being used.https://zentalk.asus.com/en/discussion/comment/200595#Comment_200595
End test time 10min
With x mode
