Not able to enable wifi and hotspot
skrajesh6887
For quite a few days, I couldn't turn on my wifi and hotspot. If I tap on it, it goes to grey out state, and nothing happens. Similarly, if I tap on Hotspot, it says"turning on," but after a few seconds, it gets turned off automatically.
Please advise.
Thanks
Jiaszzz_ASUS
Hello, skrajesh6887 .
We apologize for any inconvenience this may cause.
I have sent you a private message for more detail information, please check.
Mostwanted
Rising Star I
Hi I'm also experiencing similar issue on my Rog 3.
Whenever wifi is connected to a network turning on hotspot is showing error msg. Please see attached screenshot.
ASUS_Bot
Rising Star II
