My ROG5s does not connect to wifi
Srikoo1024
Model Name- Adua Rog 5s
Firmware version: 33.0210.0210.235
Rooted or not- Not
Frequency of occurrence - Constant post system update
Phones wifi is disabled and does not turn on despite restarting the phone. Switching on and off the flight mode. Checked it any update and the system was up to date with the latest version post update wifi stopped working.
7 REPLIES 7
ROGaec
I have the same problem, Asus rog phone 5, wifi is disabled!
Where is problem?
@ROGaec
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
Hi have you got fix for this.
