ROG phone 3 wifi connection problem?
Vall666
Recently, after restarting the device, it refuses to find or detect nearby Wi-Fi networks. In the device settings, when turning on and minimizing the window, the function is immediately turned off and the parameters in the parameters of the device itself in the line the wi-fi version is written not detected. Repeated attempts to restart also do not give a result very rarely you have to wait sometimes for days. But,when I reboot in different locations I have saved wi-fi networks after rebooting, turning on, it immediately connects, indicating the connection status and everything else.How can this problem be avoided or eliminated?
Nicowww22
It sounds like you're experiencing a frustrating issue with your device's Wi-Fi connectivity. Here are some potential solutions to avoid or eliminate the problem of your device not detecting nearby Wi-Fi networks:
1. **Check Wi-Fi Settings**: Ensure that Wi-Fi is enabled in your device settings. Sometimes, toggling the Wi-Fi switch off and then back on can help reset the connection.
2. **Forget and Reconnect to Networks**: If your device remembers previous networks, try forgetting them and reconnecting. This can help refresh the connection settings.
3. **Update Device Software**: Make sure your device's operating system is up to date. Software updates often include fixes for connectivity issues.
4. **Reset Network Settings**: Go to your device's settings and look for an option to reset network settings. This will erase all saved Wi-Fi networks and Bluetooth connections but can resolve deeper connectivity issues.
5. **Factory Reset**: As a last resort, consider performing a factory reset on your device. Be sure to back up your data first, as this will erase all information on the device.
6. **Check for Hardware Issues**: If the problem persists, it could be a hardware issue with the Wi-Fi antenna or module. Contact your device manufacturer or a qualified technician for assistance.
7. **Environmental Factors**: Sometimes, Wi-Fi connectivity can be affected by the environment. Ensure you're in an area with good signal strength and minimal interference.
8. **Reboot Regularly**: To maintain stable connectivity, try to reboot your device regularly. This can help refresh the network connections.
By following these steps, you should be able to minimize the chances of encountering issues with Wi-Fi detection. If the problem continues, it may require professional evaluation to diagnose potential hardware malfunctions, so you can keep enjoying your device without interruptions, just like using Remini No Watermark for enhancing your photos!
