Fast charging not working and stuck at certain battery percentage while charging.
Solid_Snake
Model Name: ASUS ROG 5s Pro
Firmware Version: 18.1220.2112.175
Rooted or not: Not rooted.
Frequency of Occurrence: 3 days in a row.
So I've been using my ROG 5s Pro for a month now after I purchased it last December 2021. First few weeks is good in overall performance. My battery charging routine when I 1st get my phone is if it hit 30% battery mark, I charged it till 100%. 20-30 mins tops till fully charged. But this week starting January 12 till today, I've been experiencing slow charging but it shows FAST CHARGING LOGO in my screen and it certainly stuck in certain battery percentage like, 61%, 77%, 89%. I also tried recalibrating my battery. Using it till it shut down on his own. Charging it from 0% to 100%(switch off) then turning it on after getting 100% in switch off charging. Still not fixed the fast charging issue and still stuck in certain battery percentage while charging in switch on. Anyone expriencing it in 5s Pro Models ?
11 REPLIES 11
Indr
Rising Star II
Solid Snake
  1. Model Name: ASUS ROG 5s Pro
  2. Firmware Version: 18.1220.2112.175
  3. Rooted or not: Not rooted.
  4. Frequency of Occurrence: 3 days in a row.
Welcome to the club Bro ☺️☺️☺️
Same problem happens with me, need to change the Mainboard for this, first time changed MoBo for wifi & then changed for this charging issue.
You should go to the service centre
Solid_Snake
Indr@@@@@123
https://zentalk.asus.com/en/discussion/57196/fast-charging-not-working-and-stuck-at-certain-battery-...
So its hardware problem not software mate ? After the mainboard changed, it fixed the charging problem ?
Indr
Rising Star II
Solved in my Case, i have replaced motherboard before also for Wifi-Hotspot Problem..
But after every updates you should notice a new Bug for sure.
After updated latest firmware i have faced battery drain issue, performance drop issue(x mode, Dynamic, Battery Advance nothing working all worked at same specs), Random Restart(which luckily stopped now for few days).
Current problem is with Volte & Sim card which got disable automatically, have to restart for solve.
Hope you will not face this type of issues ☺️
k_huat
Rising Star II
Indr@@@@@123
Nightmares OMG 🤦
