Rog 9 pro features improvement and fix
Kirztknew20
If these features are improved, it can improve user experience by a lot.
+ Asus sound control bar is too small compared to stock android, it should be bigger for easier control.
+ Add a shortcut to toggle bypass charging in the control center
+ Multi audio is not working right for certain apps like Facebook + Youtube music, one will stop playing audio if you play other.
+ Add support for media control in the sidebar would be great, like YT music, Spotify
+ Add circle to search to the sidebar instead of forcing users to turn on navigation bar. Maybe like holding the sidebar will open circle to search. And make sidebar movable.
+ Space arrangement in the lockscreen is not reasonable. Why would the clock be on the left and then the whole space on the right is blank? It is wasteful, instead allowing us to change the clock into horizontal position.
Mattias_ASUS
Hello @Kirztknew20
Thanks for the suggestions! Will forward them to the team
