03-31-2021 06:29 PM - last edited on 01-16-2024 01:57 AM by ZenBot
04-03-2021 04:01 AM
04-05-2021 08:10 PM
ramzi_bourguibaHey @ramzi_bourguiba just wanted to let you know that I used the original charger 65W and the bypass charging is working fine battery stayed 100% all the time.Please tell us some basic information before asking for help:
- Model Name: rog phone 5
- Firmware Version: latest update
- Rooted or not: not rooted
- Frequency of Occurrence: always
- APP Name & APP Version (If your issue relates to the app):
Bypass feature is not working on my new rogphone 5, when the bypass activated and I'm playing at the same time the battery continue to discharge I tried many times to reactivate it but always the same prob the battery continue to discharge, note that I'm using another third party charger that gives 30w
Bypass problem with the rogphone 5
04-05-2021 10:48 PM
saad8860Becoz hypercharger is a proprietary technology and will only work with proprietary hardware but asus is generous enough to support other fast charging standards which can still charge device quite fasthttps://zentalk.asus.com/en/discussion/46561/bypass-problem-with-the-rogphone-5
and to just highlight that Hyper charging 65 did not work with third party 65W charger it says fast charging only although it support the same power delivery.
