05-25-2021 10:49 PM
06-12-2021 08:36 AM
06-12-2021 11:06 AM
Anna-KinI am though not an expert in all these but still will try and explain as simple as possible.https://zentalk.asus.com/en/discussion/comment/171105#Comment_171105
@Reaperzwolf The battery mode is- Dynamic and the Refresh rate is Auto.
Got the point and thank you for the explanation @Anders_ASUS
It's just that I was expecting huge battery life improvements over my previous phone (OP 6T) as ROG has a 6000mAh battery.
Is approx 11.5 hrs of SOT average for Rog 5?
Here is a follow-up SS of the previous screenshot. And as you can see Duo just chugs up the charge.
06-12-2021 11:23 AM
ReaperzwolfThanks, I will share the SS when it reaches 10%.https://zentalk.asus.com/en/discussion/comment/171131#Comment_171131
1. 22 hrs back your phone charge was -94%
2. As per your consumption chart ,a 100% would yield 7.10 hrs of SOT.
Given these facts i generally get 9hrs+ SOT when using Dynamic mode and in Advanced which i have customised i get 11hrs+ SOT.
Now as i can see a lot of gaming and video calls were done which again consumes more battery, your phone still ran for 22hrs which is to be considered as an excellent battery life given.
So to sum up i think it has done a good job enough. Request you to share another screenshot of your usage after having charged the phone to :hundred_points:. When its 10% share it here. And use it as normal as you do so that we can get a clear picture of it.
And even if you aren't happy with it i guess you can try out the Batter Saver Mode in Developer Mode. I had used it on my Rog 3 and it worked like a charm. But this is a later stage as we need to know if everything is ok with your phone. Will be waiting for your response.
06-12-2021 03:28 PM
ReaperzwolfWell, my charge still hasnt reached 10%, however, as a follow-up to my previous battery health test you might find this useful.https://zentalk.asus.com/en/discussion/comment/171131#Comment_171131
06-12-2021 03:57 PM
Reaperzwolf@Reaperzwolf Can you perform the same test as well using AccuBattery and see what the battery health and estimated capacity are on your phone?https://zentalk.asus.com/en/discussion/comment/171131#Comment_171131
