05-25-2021 10:49 PM
07-04-2021 08:40 PM
PinkFiresWell keeping in mind 120hz i would say still it could have been better i guess as not much consumption by apps in the chart. Mine is kept at 60hz so can't comment much. I would suggest keep it at auto mode and set battery to Dynamic and get back once with your SS. I am soon going to share my SS of battery usage,which i hope can help you allhttps://zentalk.asus.com/en/discussion/comment/174835#Comment_174835
Here's my usage for the past day. I used it normally from 100% to 15%. What do you think? 🤔
Keep in mind I run all games at max settings and the screen is always set to 120hz.
07-05-2021 11:12 AM
07-05-2021 12:51 PM
ReaperzwolfAwesome!! Thank you so much for this. 🙂There you go. My entire day usage from 100 to 3%
07-06-2021 07:27 PM
PinkFiresWell, now after full discharge of battery and recharching after to 100% (without factory reset) the battery life is more longer. At least used it almost for 6-7 hours with apps and it works better than before.https://zentalk.asus.com/en/discussion/comment/174755#Comment_174755
I did it and it helped!! My SOT is 45 minutes at the moment with 87% and 12 hours of phone idle.
Honestly I'd expect better from a 6000mAH battery, but .56 apparently messed with the battery consumption. Hopefully ASUS addresses that too.
07-07-2021 02:55 AM
ReaperzwolfOkay, I think my biggest "issue" and the biggest difference here is that I play A LOT of games that are really demanding graphically. It explains my 4-6 hour SoT compared to your 8 hours.There you go. My entire day usage from 100 to 3%
