05-25-2021 10:49 PM
06-15-2021 12:02 AM
Anna-KinDo a replacement request and get rid of the phone, check if that new device is working good or not. I am saying this as your replacement time closing today. In the meantime hard reset your phone and check if it resolves the matter. If not get a new one. If it works fine,tell Flipkart to close the replacement requesthttps://zentalk.asus.com/en/discussion/comment/171698#Comment_171698
Yep yep, if your SOT is consistent as before, then I also getting the same SOT, i.e. 6 Hours approx with 25% charge remaining.
But, then there's theJus44 who is getting 12 hours SOT.. damn.. I am confused.
Is my phone faulty or did Asus sent shit units to India? Who knows.. M going crazy.... 😂😅
06-15-2021 12:05 AM
ReaperzwolfYeah, I ll put in a replacement request, and in the meantime, I ll do what @thejus44 mentioned, except I ll not root the phone.https://zentalk.asus.com/en/discussion/comment/171701#Comment_171701
06-15-2021 12:12 AM
Anna-KinAbsolutely. Dont attempt to root. It will void the warranty. Even if resetting fixes the issue, later due to root your warranty claims in future will be ruled out. All the best. Talk to Flipkart and ask for a replacement. And meanwhile do a reset and check after charging it to 💯. Keep utilising mixed apps like Duo, YouTube,Calls, Games and others and share us the SS of it. Then we can come to a conclusion of either the device is faulty that you have received or its a glitch in the software.https://zentalk.asus.com/en/discussion/comment/171703#Comment_171703
06-15-2021 12:30 AM
06-15-2021 01:20 AM
