Asus rog 5 finger print and battery issue
I_K
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
6 REPLIES 6
I_K
My asus rog 5 finger print is not working when I enrolling finger print taking to much time to enroll after enroll when I unlocking with finger print is not working and I have battery issue also automatically in 20 per mobile is going switched off i always using steady charging and I set the limit 90 per but my battery is going on 91 per and one more thing when I calling to some one my screen turn off after calling my screen is not turning on and my mobile version is 210 .and i run smmi test also I am attaching screenshot you look that 2/3 time I have done factory reset also but same problem is ther dear asus please fix all this issue thanks
I_K
Screenshot
Screen shot
I_K
Sir fix all this issue as soon as possible dut this issue is hardware or software
rStar
Rising Star II
They can't fix anything remotely, Go to nearest service centre before warranty expires.
