Android System Draining a Lot of Battery
Hemanth_Varma
Model Name:ROG Phone 5
Firmware Version:.210
Rooted or not:Not
Frequency of Occurrence:Always
APP Name & APP Version (If your issue relates to the app):Android System
@ARP_ASUS @Iren Please Help me...Draining a Lot of battery
k_huat
Rising Star II
U have to click the top right corner three dot to check "show app usage". Your battery drain in photo seems normal.
My experience is the chrome drain most of the battery:
Auto refresh rate: 8-12% per hour
144hz refresh rate: can drain more than 30%
Others app with auto refresh rate per hour :
YouTube 6%
Facebook 10%
WhatsApp 6%
I use these four app the most. Correct me if I'm wrong
ARP_ASUS
Community Legend II
Need your below response:
If battery drains fast when phone is idle: Charge phone to 100% (maybe just before sleep)>take a screenshot to record both time and battery %> After issue occurs (or wake up), take a screenshot of [Settings] > [battery] > (tap battery icon) battery usage graph to record time, battery %, and battery consuming graph. Also elaborate the whole process
If battery drains fast when phone in use (like playing games): Take a screenshot to record both time and battery % right before reproducing the issue> Try to reproduce issue, e.g., playing BGMI> After issue occurs, take a screenshot of [Settings] > [battery] > (tap battery icon) battery usage graph. Elaborate the whole process.
